98 I30 with 205K miles. got P1335 and P1335 pending for first time
infii30owner
1. how soon do i have to replace CKP sensor?
2. what is the correct part number? I see several of them on ebay.
3. does 98 I30 have one or two CKP sensors? as i read online, replacing one below passenger is enough.
thanks for help.
infii30owner
this video shows replacing CKP sensor in 97 maxima
https://www.youtube.com/watch?v=gJEN0AiLgEM
is that the right thing to replace?
plus i drive about 25 miles per day. i read in some ebay page that this repair should not be delayed too long. is it safe to drive car with this not getting repaired for a week or two?
thanks.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Never had the issue
The computer uses data from the crankshaft pos sensor to run the engine
it is a vital component and if it breaks the engine will just turn over but not start I think
Try to clean it up-it is easy to get to and it is really nasty with oil and grime down by the crank
and make sure it is getting voltage and the resistance of the sensor is within spec first
I only like OEM electronics from Nissan (except for mass airflow sensors)
infii30owner
thanks for your reply.
i thought of taking it to a mechanic. i can locate it, i'll spray some wd40 or brake cleaner to clean around it. maybe that grime went into those terminals/harness.
otherwise car has been starting and running smoothly.
should i look for one at passenger side or one at front? acdelco parts guys have two parts for this with these numbers:
180-0261 ===> youtube video appears to be replacing this part.
180-0319 right
where can i order OEM nissan parts?
thank you
NutriaforBreakfast
Here is the link for the Crank Position Sensor from the shop manual
http://www.nicoclub.com/FSM/Maxima/1998/EC.pdf
Looks like there are 2 of them
Labeled POS and REF
start looking on page 338
Page 341, 342, 346, and 348 help show location and electronic specs to test (voltage and resistance)
Again before changing them out make sure you are getting power to them first
NutriaforBreakfast
OEM parts are only available new from Nissan Dealerships
infii30owner
thanks for manual. i could click on p1335 in table of contents and jump directly to that topic.
infii30owner
I have the $60 or $70 OBD reader from autozone.
after it shows below codes:
p1335
p1335 pending
then it shows "MIL on" and when I read the codes it shows:
O2 htr
O2 sensor
EGR
catalyst
and 4 others. all are related to engine. should i be worried about others?
NutriaforBreakfast
I would clear them and see if they come back before worrying about them
just my style
infii30owner
Hi..
i got this code again, pl see new thread:
post6720874.html#p6720874
can i email you directly? mine is clad94538 _at_ gmaIl dot com or txt 408 479 9905
thank you.
NutriaforBreakfast
did you try the link to the floor shop manual previously posted on this thread?
Try testing the crankshaft position sensors with a multi-meter to see if it is within specs
Your car may have several issues as you noted;
O2 htr
O2 sensor
EGR
catalyst
Try to work each one with the shop manual. If your car has never had O2 sensors or an EGR valve
it probably does since it is high mileage (in my opinion). I think "catalyst" means the catalytic converter issues.
Sometimes just a general cleaning of the throttle body, idle air control valve, and EGR tube will cause some
of the these codes to go away. You should find a lot of information by searching the website about this
type of maintenance which costs very little money.
infii30owner
after i sprayed and cleaned both ckp sensors, the check engine light went away.
however, smog test failed with high NO at 15mph. what could be wrong?
thank you.
infii30owner
except the high NO value at 15mph, every thing else passed. NO, HC, CO2 etc at 25mph are all good.
car runs pretty smoothly.
NutriaforBreakfast
The EGR valve generally is responsible for NOx cleanup
Sounds like the exhaust gases are not being reburned
Or it might be the catalytic converter
IF the engine was at normal operating temperature the NOx might be lower and you might pass
infii30owner
i had oil change done maybe 2 months ago. when i checked engine oil with dipstick a week ago its close to low mark level. would driving car with that oil level cause engine to run at high temp? car is over 18yrs old. it must be slowly leaking oil through the gaskets. i don't see any oil on my driveway though.
i'll also try techron fuel line cleaner at my next empty tank.
a local mechanic sprayed some seafoam through air intake two days ago. it seems to run bit smoother now.
lot of places say it has to be clogged EGR tube that causes high NOx as the exhaust gas is not being recirculated.
http://www.aa1car.com/library/egr.htm
https://axleaddict.com/auto-repair/EGR- ... ep-by-Step
but i didn't find any videos or pictures for cleaning EGR tube specifically for I30. appreciate if you can send any pointers. i didn't even find any websites selling that EGR tube, if i just wanted to replace with new one.
i'll try fuel injector cleaner, refill some oil and try to get the EGR cleaned before i go for retest.
