maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Thu Jul 21, 2005 11:59 am
Only use premium unleaded, that is what the car is designed for. I believe if you run low octane fuel, it can cause the knock sensor to throw a code. Simptoms of a bad KS would be low mileage and poor performance. You may want to run a tank of premium through there, reset the computer, and check to see if the code comes back. You'll have to check manually for the code as the KS code does not turn on the CEL.
