jto »
https://forums.nicoclub.com/jto-u12675.html
Fri Jun 02, 2006 4:11 pm
Hi,
I'm getting a loud knock coming from under the timing chain cover. I'm pretty sure the chain needs to be replaced. It knocks really loud when it's in gear at 1000-1500 rpms.
With 120k miles, I'd like to change it. The only thing I see that would get in the way looks like an engine mount of some sort that bolts to the passenger side fender well to the motor. Is it ok to unbolt this to get to the small timing chain cover bolts? I'd hate to see my engine collapse on the fenderwell or something.
I don't believe I have to retime it unless someone here tells me different. I could use some quick advice on how to do it if it needs to be done.
If anyone can chime in with some hints it would sure be appreciated!
thanks in advance!
