Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Tue Aug 28, 2007 2:59 am
Your problem may be simple.
The cooling system in these cars is a pressurized system. If the cap is loosing pressure, then the system will boil off your coolant.
I would start with replacing the cap. Then I would cosnider a full system flush and replacing the coolant. If neither of these solve the problem, I would consider replacing the water pump and having the radiator serviced or replaced.
As far as the plugs, you should be able to reach the rear plugs without removing the intake. You will need a long extension and possibly a swivel. The QX4's send a spark plug wrench in the tire kit for the driver's side bank. Maybe the I30 did the same.
