this is a 98 i30 with 215K miles. i cleaned the CKP sensor, which was pretty greasy with oil, that is on passenger side below crank shaft pulley 5 months ago with brake cleaner and CEL went away. now its back again. i'd like to fix the leak. what are the possible oil leaks for this car? i recently changed transmission fluid and i don't think its leaking. i also smell strong burnt oil at times.
i took pictures where we put engine oil and around it. its leaky around the edges.
Here are the pictures: https://goo.gl/photos/vdrG1wMXhGzMtFHNA
appreciate any pointers.
thank you.
