jasonG79 »
https://forums.nicoclub.com/jasong79-u146147.html
Sat Jun 26, 2010 7:45 pm
Would a bad TPS cause hesitation when accelerating?
Here is what my car has been doing: when I accelerate from a complete stop the car does fine until about 35-40mph, then it seems to be bogged down until it get close to 50mph. After that it does fine all the way up to freeway speeds. It only seems to happen when I'm accelerating at a normal pace, if I floor it there are no issues. Also, sometimes when I'm on the freeway and need accelerate to pass, she hesitates for a second then goes.
About a month after buying the car the cel light came on, took the car to get the codes read and it showed the codes for TPS. I decided to try cleaning all the connections before buying new parts, problem went away. Now the cel is back with the same codes.
No way around buying a new one this time. My big question is would this be causing my problems or should I be looking elsewhere for the problem? I suspected the transmission might be the problem but when I did a fluid and filter change, the fluid was in excellent condition (not burnt or discolored at all), so I put that idea towards the back of the list of what it could be (still very well could be my problem, the car does have just over 190K).
Full tune up was just recently done including fuel filter. The only thing I havent done is change the coil packs.
Anybody have similar issues or thoughts
Jason
