Dirtybob »
https://forums.nicoclub.com/dirtybob-u312185.html
Sun Feb 18, 2024 1:03 pm
Hello all, first post here.
I have a 98 Frontier, ka24de, 5 sp, 2wd that's got me stumped. It's recently started missing when in closed loop (runs perfect when cold). Only code that comes up is cyl 2 miss (po302).
Pretty sure this would be a sensor issue but I've replaced the CTS, MAF, and O2 sensors within the last few weeks. Also threw in a new set of plugs, fuel filter, and regulator. Fuel pressure looked good, injectors sound good (stethoscope) and ohm testing has them all about the same (I forget the numbers but were +/- 0.1 of each other). None were leaking (key on, engine off). Distributor and knock sensor replaced last summer (code & no spark). Not finding any vac leaks, scan tool reports 24kpa idle (my mech. gauge quit working). EGR appears to be functioning correctly.
Engine idles fine hot or cold, but after entering closed loop it misses badly from off idle until the rpms come up (maybe 3k). If I put my foot in it (after closed loop) it has no power and feels like it is missing on multiple cylinders rather than the reported cyl 2 miss (bad coil?).
