'98 Altima Engine into '91 240?
base9se
Car: '95 240sx
I found this engine on ebay http://cgi.ebay.com/ebaymotors...photo and I wanted to know if this would have no problem fitting into the '91 5-speed transmission I have now. What do I need to make this work? Thanks.
s13sr20chris
problem no one would be the manifold facing backwards. you could solve that by using the 240 manifolds. problem no two would be the dist facing backwards. you could solve that by using another 240 motor. sorry bro. maybe some parts will swap though.
base9se
Car: '95 240sx
Which year of the altima engine would work then? If any?
s13sr20chris
well, none that i know of. unless you figure out the dist thing. they all have dist poking out of the area over the transmission. of course that space will be taken up by firewall on a 240.
