s14280zx »
https://forums.nicoclub.com/s14280zx-u40679.html
Sat Dec 09, 2006 3:15 pm
Last year I had a local transmission shop put in an ACT Extreme pressure plate, perf. street disc, and release bearing/pilot bushing, and a Fidanza aluminum flywheel. It worked great up until recently, but one morning I drove to work(30 miles) and it worked ok. The car sat in the sun all day, and when I went to go home, the clutch pedal felt really stiff, and the clutch wouldn't grab until the pedal was all the way out. I changed the clutch master cylinder,and slave cylinder with new nissan parts, thinking this would take care of it, and bled the system with a vacuum bleeder, but now, When the car is cold, the pedal feels real easy, but if you drive it 30 minutes or so, the pedal gets real stiff again, and slips above 4500 rpm. Any suggestions on how to fix this would be appreciated.
