s14280zx »
https://forums.nicoclub.com/s14280zx-u40679.html
Tue Mar 20, 2007 2:58 pm
Update: When I changed my mast. cyl., slave cyl., and line, I bought a copper crush washer(universal ) from advance auto. When I eliminated my clutch dampener, I bought a new nissan crush washer(between line, and slave). Turns out the nissan washer has a smaller inside hole than the universal one. I think this was my problem all along. When it heated up , it expanded and let air in the line. The pedal feel is 100% better without the dampener, and it isn't much harder to push in at all. I would recommend for anyone with a s-14 to get rid of their dampener. Took 2 minutes to bleed also. When you buy your stainless line from SPL, get a speed bleeder with it. Just crack the bleeder half a turn, fill the reservoir, pump it a couple times,tighten bleeder, top off the res., and your done. Hope this helps someone else with the same problems I had. Thanks for everyone's advice.
