thats probably what i would do. if the circuit is closed when the button is pushed like navysnail said, then you can cut the switch out, connect the two wires and call it a day. or if you want to be safer than that, just find a switch at a store and just flick it on when you need to start.c-rad wrote:How about just bypassing the switch altogether? Just make sure it's not in gear when you start it
