97Q45t »
https://forums.nicoclub.com/97q45t-u4872.html
Mon Jun 20, 2005 2:38 pm
Yes, the Z32 diff has cooling fins at the bottom vs no fin for the Y33's. I liked the fins so I kept the Z32 rear cover.
The ABS rings/sensors are the same. They will fit perfectly. The ABS sensors used silicon beside bolts, so when you remove them try to twist the sensors first to break the silicon before pull them out.
Nothing's wrong with the 4.083 yet. 300-400 miles so far. Gas mileage is about 8-10% worse than before, just as I expected.
Hope you win the diff too!
