97j30vlsd
clearview
is the rear of the 97 j30 vlsd w/ abs considered the r200 rear in the s-14. will nissan racing ring and pinion gears fit in the infiniti rear. racing set is 200mm OD,128mm ID. 12mm gear bolt w/1.25 thread pitch.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Probably should be moved to Nissan/Infiniti Engineering, or Infiniti Mechanic Forum.
diamondj30
Car: Not to low , not to high , just right .
i use nissan sport 436 gears in my j30.sorry thats all i9 know.
clearview
Diamond J.
where did you get your gears.Bill
diamondj30
the shop who installed them got them from nissan motor sport.that is what they said.
Eswift
Car: should be obvious enough
J30 has r200v rear end
