Movement issues:
Put into Reverse, nothing happens. Put it into Neutral and its moving forward.... interesting. So it thinks its in Drive. Put into Drive and the same happens. Buuuuut, 2 and 1 it is acting like its in Neutral so the car will rev but no movement.
Park car, listen to motor, listen to trans going trough gears at a stop. Put it back in to Park and....... Now Reverse is working as it should. Neutral is acting as it should. BUT D, 2 and 1 are all acting like Neutral. Car will not move.
So basically the car moves forward and backwards under its own power but i cant control which one I get lol. Currently can only go backwards, kinda silly.
Any ideas if someone has seen something like this? Trans fluid looks and smells good and proper level but Probably still going to flush it anyways just to see.
Ive only begun working on this car but was hoping on salvaging it. The previous owner was going to sell it for scrap but the interior is nice and exterior is straight and decent. Motor runs good too so I see no reason to let it go to waste.
Some pics just cause.
