malibumarlin »
https://forums.nicoclub.com/malibumarlin-u187138.html
Thu Jul 21, 2016 11:34 am
I've owned my '97 XE king cab since new. It has a camper shell on it (300lbs). I am meticulous with the maintenance. Today, with 215,000 mi on it, I still average 27 mpg hwy without any load other than myself and the shell. When loaded for a camping trip into the mountains (Driving 1200 mi round-trip from sea level Los Angeles up to 9000 feet in Utah/Arizona and back), I'll average 17-23 mpg.
It could do better mileage. Using a scan tool to monitor fuel trims - especially LTFT will tell you a lot about your engine health. Learn how to use one beyond simply reading codes will help you a lot. Likely, with the age of your vehicle, low mileage aside, you'd do good to inspect/replace all of your vacuum hoses. The EGR and it's vacuum hose is especially easy to miss because of it's location and especially vulnerable to deterioration.
Another pesky problem that seemed to repeat itself on my engine are the wire leads of the MAF. Easy to overlook, but will create a big problem. Use a magnifying glass to inspect the wires and housings at the MAF sensor plug. If it's cracked or broken you'll want to fix this.
Changing the oil filter is another task that will require patience, technique & TLC. Left a service tech, you'll likely be left with a torn fender skirt, oil everywhere, and worst off, because of it's proximity to the alternator wires, a sloppy rushed job can lead to broken wires - which will eventually leave you stranded with a burned out alternator.
