ianh »
https://forums.nicoclub.com/ianh-u51586.html
Thu Sep 04, 2008 4:01 am
First comment is that if you change the cluster you go down to your Nissan dealer and they put a sticker on the car with the mileage correction / history...so no problem. ( or you just declare mileage unknown)Second this cluster change has been done and i did it to my 97 GXE.This is not for the faint of heart.There is / was a write up with all the details 99SEL's web site.You need a cluster from a 200SX 1.6 manual....I found mine on car-parts.com with same mileage as my car for $50 from a wrecker about 200 miles from my house..what you do is add the wire from the ECU, remove all the pins from the 3 cluster plugs and re-wire them for the "new" cluster. You also have to add one ground lead, i used a spare wire from the "new" cluster, they just cut the wires to the plugs.BTW This was useful as all the colors were there to aid in the re-wire.If you want to proceed i may be able to find word files on this.
The E-bay add does not say whether this is a 1.6 or 2.0 cluster ?Both work but the red line is different, and i believe other differences.
