MadPSI »
https://forums.nicoclub.com/madpsi-u1800.html
Sun Jul 10, 2005 10:46 am
I have been challenged to fix my friend's pesky little Sentra that's being retarded... The following are Cliffs Notes on what has happened so far:
- Car was stolen, returned with Check Engine light on...- Car taken to emissions for OBDII check (bulb check, whatever that is...) - Key off/crank test = PASS - Key on, running, etc. = FAIL - Every other reading on the sheet (MIL, etc.) = UNABLE TO COMMUNICATE
- At this point, I poke my head around underneath looking for loose plugs & wires, everything seems intact. So I go to AutoZone for a redundant OBDII check...
- Autozone OBDII scantool check (car on, but not running) = EGR flow failure (at least it connected)
Now, is the "UNABLE TO COMMUNICATE" stuff in any way related to the "EGR flow failure" reading I got from the scantool? Are there two separate problems?
Will the emissions place let you do a non-OBDII test in an OBDII car given extenuating circumstances?
Thanks In Advance...-Brandon
Modified by MadPSI at 5:16 AM 7/11/2005
