I recently bought a Strut Mount kit from Oreilly's Auto. There is a spacer in the box that I don't know where it exactly goes? I looked at the FSM and didn't find the spacer anywhere in the diagram. Doe's anyone know what it is for?
Postby
iFly QX4 »
https://forums.nicoclub.com/ifly-qx4-u218073.htmlThu May 02, 2013 7:03 am
I believe that's the Strut Mount Bearing in the picture. In page SU-8 in the FSM it has the exploded diagram of the front suspension and the part #4 is labeled 'Strut Mount Bearing'.
I'm going to try to post a pic of my left strut taken apart.
Postby
iFly QX4 »
https://forums.nicoclub.com/ifly-qx4-u218073.htmlMon May 06, 2013 6:47 am
I initially assumed that spacer next to the bearing was the top nut securing the strut to the mount, my bad. I have completely disassembled both strut assemblies on my QX4 and there is no spacer, so 'itsnotme' is correct, no spacer needed.
Postby
DAiNiUS »
https://forums.nicoclub.com/dainius-u166718.htmlThu May 09, 2013 6:29 am
You don't need that spacer. It also had me puzzled when I was getting my struts changed. My guess is that these kits can be used on several different makes and models, and maybe some of those models require the spacer.
