NISTECH wrote:When it wont start. Does the engine crank but not fire or does the engine not crank at all? This would lead me to think starter if its not cranking at all. Giving it a wack while holding the key in the start position usually gets it to start turning the engine.
If it cranks but doesnt fire up you need to find out what the engine isnt getting at the moment of failure,fuel or spark. I know your some distance from the vehicle but this sounds like a complex issue that will require at a minimum a fuel pressure gauge for accurate fuel pressure readings, and a noid light to check injector pulse at the moment of failure.
You should probably make sure your engine control harness grounds are clean and secure on the intake plentium. They are located either at the front of the plentium right next to the distributor or on the middle of the intake along the harness. may need to loosen them clean them with a wire brush and resecure them.
Thanks again-When the "no start" condition occcurs, the engine cranks just fine and without issue. The starter is relatively new.
The fuel pump, and the fuel pressure regulator have been replaced, and the pressure tested. It checks out ok. At last inspection, the engine was getting fuel and spark. Now i'm not sure if a noid light has been used to check the injector pulse, so I'll look into that. Good tip on the ground. I'll have somebody check those, too.
I just got word this morning that it threw a CEL, so I'm shipping off my OBDII reader today so that code can be pulled. Hopefully the CEL will shed some light on a possible problem. I honestly don't know what else could be physically wrong with the car; nearly everything has been replaced, it still has decent power, gets great mileage, etc.. The only thing left that I can think of that could possibly be malfunctioning is the IAC, perhaps.
You see, I personally drive a Toyota 4Runner, and I fee very comfortable working on it. But at this point, I'm by no means a pro mechanic, and I can't help but stab in the dark from 1500 miles away. I'm only going off of what I observed when I tinkered with it last month, and what I'm told daily by phone.
