97 QX4 MAF vs 98 Pathfinder MAF (Swappable?)
NismoPick
Car: 97 Infiniti QX4
00 BMW 528i E39
94 Geo Metro
87 Toyota Pickup
81 Datsun 280ZXT
I got the dreaded OBD-II codes P0325 & P0100 on my 97 QX4. Pulled, inspected, and cleaned MAF with MAF spray cleaner. No change. Ordered a new MAF on ebay... backordered 20+ days from Japan. I've read about Maxima MAF swaps for 01+, but not for a 97. I hit the junk yard and found 98 Pathfinder and 98 Quest MAF's.
My 97 QX4 part# 22680-2J200
98 MAF part# 22680-5J000
So I compared the FSM tests / specs for each. The only difference is engine speed at 2500 rpm: (97 QX4) 1.7V - 2.3V vs (98 Pathfinder) 1.5V - 2.1V.
Page 103:
http://www.nicoclub.com/FSM/QX4/1997_QX4/ec.pdf
Page 121: http://www.nicoclub.com/FSM/Pathfinder/ ... der/ec.pdf
Is this difference in voltage range enough to make it still reject the new MAF? This won't be a permanent fix... just until the right MAF comes in the mail.
NismoPick
00 BMW 528i E39
94 Geo Metro
87 Toyota Pickup
81 Datsun 280ZXT
Well I installed the 98 MAF and took it for a drive around town. No stuttering and no CEL like it was doing before. Seems to work fine.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Thanks for sharing the result!
blkqx4
Car: 1999 infinity qx4
Nismopick Can u discribe the problem u had when ur truck starting acting up why u change the maf
NismoPick
00 BMW 528i E39
94 Geo Metro
87 Toyota Pickup
81 Datsun 280ZXT
Sorry, just saw your post.
The first time it happened, it died when I stopped at an intersection. Put in neutral and it started back up but would rpm surge every 30 seconds or so. Limped it home, let it cool off, and drove it again. Didn't have any problems until it got up to operating temp, then every time I'd stop it would die. CEL popped on. First time there was only P0325 (knock sensor). Did research, went to Radio Shack and bought resistors to bypass the knock sensor, no change, this time P0100 and P0325 appeared. I chose to buy an OEM MAF from eBay for $75 instead of $250+ AutoZone ones, but they were on back order (gotta love ebay sellers who relist without checking inventory), so I went junk yard hopping and found the other for 98+ models (see my first post). Popped it in and no more problems. I finally received and installed the OEM replacement and have been driving with no problems since.
