The minivan does have a few issues that I wanted to ask y'all about.
1) Something makes a raspy, grating noise when I accelerate. It's only when I push the gas pedal down a certain amount. It doesn't seem to matter what gear I'm in. Mostly, it happens when I'm climbing a hill. I made a video while driving uphill -- I know there's a lot of road noise too, but you can hear the difference when I let off the accelerator a couple times: https://www.youtube.com/watch?v=gWERq3a9FCE
It sounds pretty scary, I really have no idea what it is.
2) The whole car wobbles at speeds above 55 MPH. It could just be unbalanced tires, I might have them balanced, but before I spend $16/tire I thought I'd check if this is a common problem -- I read somewhere that there can actually be an issue with the rear brakes that causes a vibration that feels like it's coming from the front? Or, maybe it's related to problem 3 or 4...
3) It seems like something is loose in my suspension/steering. When I go over speed bumps or similar, there's a clunking sound especially from the left front. The direction of travel is not very consistent -- for example, if I have it in cruise control and I'm climbing a hill, when it downshifts into a lower gear to get more power it pulls to the right and I have to correct the wheel to the left; when it shifts up again, I have to correct to the right. When I'm taking a curve on the highway (I think it's only when turning right), there's sometimes a point where something shifts and suddenly I am turning more sharply to the right even though I didn't move the wheel. I had the car looked over by a mechanic when I first got it and he noticed that my left front ball joint was broken, I replaced it and got an alignment but this is still happening.
4) My parking brake light is on permanently. Is it likely a broken sensor, or is it possible the brake is still applied a little bit? The action of applying and releasing the brake seems to be normal, and I don't notice excessive drag, but maybe it's dragging a little bit and contributing to the wobble or steering issues?
And finally, this isn't a specific question, but is there anything you recommend I do as preventative maintenance? The mechanic said there was a drip from the main seal, between the transmission/engine; is that a big deal?
Thanks so much for any help you can give me
