Lokim »
https://forums.nicoclub.com/lokim-u160520.html
Thu Oct 06, 2011 8:15 pm
Another thing to try, being that it is cheap and easy and it likely needs it anyway, is buy a can of throttle body cleaner (I like 3M's, around $5) and grab an old toothbrush and a rag. Take the intake hose off and spray the throttle plate liberally, open the throttle and spray the throat liberally as well. Scrub with your old toothbrush, spray a bit more to rinse, and wipe clean with the rag. Repeat until shiny and spotless (or you run out of cleaner.) Do this to BOTH throttle plates, TCS and and accelerator pedal-linked. See the FSM.
I'm not a subscriber to maxnix's school of thought. I respect his opinion, but I think you can drive whatever you want, as long as you're willing to learn how to fix it and equip yourself accordingly if you can't afford for someone else to. Parts for these are pricey. If you're willing to make the necessary sacrifices, by all means, keep your Q alive! If you are unable or unwilling to learn about and fix your Q, than I do think you should consider more "user-friendly" wheels. Just my 2 cents.
