The factory radiators only have ATF coolers, there is no oil cooler built into the radiator on any Q45.
Regarding the heater, does the engine seem to be at operating temperature? Coolant is all the way full? Nissan engines are typically pretty good about bleeding the air out themselves, so usually air doesnt get trapped inside... In the FSM (
www.nicoclub.com/FSM), you can look at the HA section and do some of the tests... There is one where the heat should be on full blast, and that will help determine your problem...
