qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Sun Aug 26, 2007 8:49 am
disconnect one line at radiator while helper starts car and you watch the disconnected line- if atf rushes out of rad side you have found the return line,if atf rushes out the rubber hose side,you have found the inlet side-have helper shut off motor as soon as you determine the above!
