Quite easy to compare the rubber compound hardness with a Shore Durometer. As each hot cold cycle makes them harder and harder and harder and harder!
http://www.racerpartswholesale.com/long ... 21-tc.html
Generally the practice of buying AS tires just before Summer is counterproductive since the summer heat fries the rubber making it significantly worse [harder] for winter [cold] driving when you need soft the most.
The point I was making is that generally oem tires are soft BECAUSE mileage is not a factor [within reason] and the factory is only interested in showing off good braking [wet and dry] and handling numbers for magazines.....coupled with what ever ride standards are appropriate for the class of vehicle. Everybody involved in the tire business knows there are trade off.
Since most people don't want REAL performance tires but desire low cost and long life......the higher numbers are more suspect than the lower ones.
The problem with tread wear index is that it is extrapolated from the 8,000 mile runs on the Texas Highway Test Track and only shows a relative number compared to other tires in a single company's line......but with lower numbers [100-220] in all likelyhood you are getting a soft tire -- as to my knowledge there has never been a race to see who can make the FASTEST wearing passenger tire!If you are doing around town driving only [without significant extended highway] these index numbers mean little or nothing!Since agressive turning, braking, and WOT acceleration are what wear tires not 20,000 miles at a steady 70 mph [assuming the aligment is correct].
Sometimes the least expensive 17" is good enough especially if you change them every 10,000 miles instead of trying to get 20,000 out of them. Since on a wider tire tread depth is very important in turning in the rain at least till the standing water exceeds the depth then the compound softness takes over as the limiting parameter.
I subscribe to this policy if tire rack is having a special on an obsolete model [that had a good reputation in the past] I jump on it knowing that at half price 10-15,000 miles is getting my moneys worth.
It would be great if TireRack would do some half worn wet tests on the same tires they tested new but I doubt they could get their drivers to do it for safety reasons.
Remember the US DOT reported that over 66% of the tires currently sold will not meet the new proposed safety standards when brand new. So my guess is less than 10% will do so when half used!
http://www.rma.org/newsroom/20...s.pdf
