pnanda16 »
https://forums.nicoclub.com/pnanda16-u3019.html
Fri Dec 29, 2006 12:20 am
So I was driving from LA to San Francisco this afternoon and in the freeway with some traffic, I started seeing some hesitation, like when I left the accelerator pedal, the RPM dropped (naturally) and then I would see the RPM go up by itself and I could feel as if the transmission was going one-gear up, and then go back to the OD and RPM would fall again. This happened three four times whenever I took my foot out of the pedal (no acceleration). Right after than, the TCS-OFF, SLIP and SES lights came on. I tried calling infiniti dealers close-by to see if the car needed immediate attention. After the lights came on, the car went to fail-safe mode and the torque-converter lock-up didn't work. Other than that, I could drive the car just fine. When I stopped at the next gas pump and turned on car after a few minutes, the TCS and the SLIP lights went away but the SES light stayed on and still does. Drove another 200miles to bay area and didn't see that problem surface.I came back and did a lot of reading in this forum and read a lot about how relays could be a problem, alternator could be possible issue, TCS/ABS actuators etc. Then I read somewhere that the Y33s (my car) don't have the alternator problem that the G50s used to have. So I am a little confused as to what to do. Tomorrow morning I am taking it to autozone to get a code reading. What should be my next step? I have a pioneer HU which shows voltage supplied at 13.x volts when driving, so I am assuming the voltage regulator is not the problem. Because it seemed like the transmission was hesitating, is this a transmission problem (I really hope not!)?
Appreciate your valuable input. My Q has been running great all along.142K miles, all fluid flushes done every 2yrs..thanksPhal
