Ok so I bought an ignition coil from infinitipartsusa.com(Scottsdale Infiniti) and was shipped and ignition coil. I removed the old ignition coil and installed the new coil by following Chiltions steps:
PATH: Engine Electrical > Distributorless Ignition System > Removal & Installation > Ignition Coil Module
1.Before servicing the vehicle, refer to the Precautions section.
2.Disconnect the negative battery cable.
3.Remove the engine cover.
4.Remove the air duct and air cleaner assembly.
5.Move the heater hose and its peripheral parts aside (No. & cylinder).
6.Disconnect the harness connector from the ignition coil.
7.Remove the ignition coil.
NOTE: Do not drop or shock the coil.
To install:
1.Installation is the reverse of the removal procedure.
2.Tighten the coil retaining bolt to 36 inch lbs.
I started the car and now have a service engine light, TCS off light and SLIP light on. I test drove it around the block to see if it would clear and it did not. The car will now not get out of firt gear so it appears. I removed everything again and took off the coil and this time looked at the coils very carefully and found this difference:
New ignition coil is labeled: IBG+ 22448 3H000 HANSHIN MCP-1320 NISSAN T2
Old ignition coil is labeled: IBG+ 22448 6P000 HANSHIN MCP-1300 NISSAN T1
Not sure what the difference in numbers mean, can anyone help??? I put the old coil back in and I am still getting the same 3 lights and the car is not going out of 1st gear...
