'97 q45 rear-end output shafts
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
BoostFab
Car: S13cp, S13fb, S14z
the q45 section seems to be too quiet over there, but I'll try this here:
has anyone swap out the 1997+ q45 rear end output shaft with the ones from the 1991-1996? since the 1997+ newer has a 5 bolt flange output shaft, i don't have both in front of me, but can some one confirm this!?
SuperHatch
Car: 96 TLC
BoostFab wrote:the q45 section seems to be too quiet over there, but I'll try this here:
They are not interchangeable. The G50 diff has 6x1 flanges like the Z32 TT and GTR because the spline count going into the diff is actually greater as well. This makes the diffs in those cars stronger.
Your diff is interchangeable with Z32 NA, J30, S13, S14, and all of the output flanges will swap as long as they are from a diff with a viscous LSD.
I hope this helps...
BoostFab
thanks for the input.
Return to “VH45DE / VK45DE / VK56DE Forum”
