the converted wrote:You are either going to hvae to go aftermarket or find one in a junk yard. You will need an amp if you can't find a factory replacement speaker.
Well, that was the question. So, if I replace one with an aftermarket, I have to do both, because they will need a seperate amp? Andy didn't have a speaker, but I located one in San Diego, so we'll see if it works or not. If not, I'll be going aftermarket. I found a few options on Crutchfield for 6.5 woofers, because I don't want to put a big box in the trunk. The trunks are small as it is.
