97 q45 power is weak
grip1968
Car: 2000 Nissan Maxima
My q45 is very weak when I take off at a light, but then it drives fine. I had my Spark plugs changed recently. My SES light cam e on I pulled the code its saying P0325 one & two (Knock Sensor). Do I need to get these changed. or should I try some BG 44 first. How much for the parts & labor for the KNock Sensor...
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
grip1968 wrote:My q45 is very weak when I take off at a light, but then it drives fine. I had my Spark plugs changed recently. My SES light cam e on I pulled the code its saying P0325 one & two (Knock Sensor). Do I need to get these changed. or should I try some BG 44 first. How much for the parts & labor for the KNock Sensor...
zerothread?id=420801
My thread regarding knock sensor changes on our (97-01) q45's.
It is NOT an easy job for someone that doesn't turn wrenches - it will cost you anywhere from $600-$1000 at a dealer - this isn't including whatever OTHER parts they determine need to be replaced (injectors with broken pintle caps, etc....)
Epod
Car: 1998 Q45 129k
Did this "weakness" start right after the plug change? What plugs did you put in?
grip1968
no it started about 3 weeks after my plugs were changed, I used NGK PF PLUGS..
