97 Q45 Odometer not working
Eavamnba
I have a 97, all the gauges in the cluster work but not the odometer? Could this be a simple problem like a fuse?
Thanks in advance!
ProudNissanFreak
Car: 2005 Imaginary WRX STi, 2003 Civic
Possibly a bad sensor. Might wanna check that out.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
No fuse on that, I believe the 97' is stilll mechanical. Your odo cable might have just gotten loose.
Anonymous User
Car: 1997 Q45
I have the same problem. I have been trying to figure it out also.
BadQ45t
These should be an issue that any good general mechanic can diagnose and fix very quickly.
ConceptRZ
Car: '99 Q45
Also have this issue on my 98 Q. Speedo works, but not trip odometer or mileage odometer!
Does anyone know for certain if this is a sensor (on diff perhaps??), or cable! Also, I wonder if it's at the cluster side or on the drivetrain side.
Thanks!
qwertyz
Car: Nissan S14 AWD
there is no cable on 97-2001 q its electrical
if ur speedo works but the milage dont (mechanical numbers 97-98, ) probably striped gears in a cluster. (exept 99-01 digital cluster)
