JP94ZJ »
https://forums.nicoclub.com/jp94zj-u38101.html
Mon Mar 06, 2006 7:06 pm
I have 97 Q45 and the ABS, TCS OFF, SLIP light are all on. Scanned cpu, pulled codes:ECM-ABSTCS COMM NGThrottle Position Sensor 2ABS Motor Failure (OFF MODE)
What gives? I checked the connections and they look good, the fuses are all o.k. I couldn't find the ABS relay though to check to see if that's working. Is this some sort of Fail Safe mode? I don't even know where to start the diag. I am not very knowledgeable of all this electrical junk.
Any help is appreciated.
Thanks
