My '97 Q with 75,000 miles has been at the dealer for the past 10 days for warped rotors and because the ABS/SLIP/Traction lights are on.
Turns out, the warped rotors caused the ABS relay to burn out. ABS relay has been replaced and the dealer has knocked $200 off the labor to diagnose the problem, in part, because they turned the rotors 13,000 miles and 12 months ago.
So now I face turning the rotors again, or replacing them. I was thinking about slotted or drilled Powerstop rotors, but after reading the threads here it sounds like there is considerable support for the OEM rotors.
My question is: Should I go with Powerstop rotors figuring they're cooler and won't warp as quickly, or should I replace them with OEM rotors? Am I faced with warped rotors every 13,000 miles?
