97 Q45 Bose Stereo Volume Control Problems
srwood1
Car: 1997 Infiniti Q45t
The volume control on my factory Bose Stereo unit has slowly over time quit doing it's job. Most of the time it does not change the volume at all, unless I push or pull on it while turning - and even then it is hard to get the desired results. Sometimes when decreasing the volume, it will go up instead - and visa-versa. I'm afraid I'm going to inadvertantly blow out my speakers one of these days.
I thought I might be able to pop off the volume knob and spray some rheostat cleaner, but the knob doesn't want to budge.
Any ideas? Does it have a conventional rheostat?
Thanks
Q451990
srwood1 wrote: Does it have a conventional rheostat?
I'm not sure when they made the change-over to the "counter" style knob, but the newer radios use a knob that never stops in either direction. So you can turn it clockwise or counter clockwise and never reach a stop. If that's the case on your radio, then it's not a conventional rheostat - it's two switches that count the knob as it passes a point somehow... so the only signal it gets is either "up" or "down" signal just like pressing a button up or down.
So maybe you could clean those switches? Or look for a low-mileage ebay replacement...
Heath
