I don't. If you went with something that's not silicate-free, you may be doing long term damage, but it shouldn't be causing this.charmessence wrote:I will say that I did not use the Nissan antifreeze coolant and instead went with the autozone/advanced auto equivalent store brand. Do you think using the auto-zone/advanced brand equivalent coolant would matter?
Thanks Skibane!Skibane wrote:Obtaining a genuine Infiniti factory service manual (or "FSM") would be a HUGE help.
It's available for download for free, or you can buy one on CD-ROM for cheap on ebay.
Without one, you typically spend a lot of time guessing about the cause of the problem, or spend a lot of time online researching the fix for it. Unless you plan on relying on a dealer or independent mechanic to fix and maintain everything, you really, really, really, really need one.
Q451990 wrote:I don't. If you went with something that's not silicate-free, you may be doing long term damage, but it shouldn't be causing this.charmessence wrote:I will say that I did not use the Nissan antifreeze coolant and instead went with the autozone/advanced auto equivalent store brand. Do you think using the auto-zone/advanced brand equivalent coolant would matter?
Heath
I'm not sure, but it looks like the Bi-Level Door Motor is behind the Auto Amp (what you referred to as the A/C unit)...charmessence wrote:Ran the diagnostics and the error codes 26 and 27 came up which indicate air mix door and bi-level door issues. I am now trying to research a way to get to the bi-level door. Do you know if this requires breaking down the entire dash unit?
Skibane wrote:I'm not sure, but it looks like the Bi-Level Door Motor is behind the Auto Amp (what you referred to as the A/C unit)...charmessence wrote:Ran the diagnostics and the error codes 26 and 27 came up which indicate air mix door and bi-level door issues. I am now trying to research a way to get to the bi-level door. Do you know if this requires breaking down the entire dash unit?
...so it might be accessible by pulling the radio and Auto Amp out of the dashboard.
Is it possible that the connectors on the Door Motors were disturbed when the Auto Amp or heater core were replaced? Also, several of the wires on the Bi-Level Door Motor and Air Mix Door Motor go to the Auto Amp, so a loosely-seated connector on the Auto Amp itself could cause the problems you're seeing.
Thanks Heath!Q451990 wrote:I really don't know on your version of the Q. I'm guessing you'd have to take the glove box out at a minimum. There should be some diagrams in the service manual. By the way, it's available right here on NICO at http://www.nicoclub.com/FSM/
If I remember correctly the 1997 manual is incomplete, but the 1998 version should be essentially the same.
Heath
Been working on the heat and MAF on the q over the weekend..... Have not found anything yet but wanted to note that I disconnected the Ambient Sensor and the car actually started to get warmer not sure why though. I am still working to figure something out any ideas or info would be greatly appreciated (got the MAF cleaned and runs like a champ! thanks to those who posted procedures on cleaning the MAF!)Skibane wrote:I'm not sure, but it looks like the Bi-Level Door Motor is behind the Auto Amp (what you referred to as the A/C unit)...charmessence wrote:Ran the diagnostics and the error codes 26 and 27 came up which indicate air mix door and bi-level door issues. I am now trying to research a way to get to the bi-level door. Do you know if this requires breaking down the entire dash unit?
