BadQ45t wrote:Thanks, the regulator is for sure jammed.......Either way they have to take apart the doors which sucks. I have 97k on the car.
the good news is that I am pretty confident Nissan upgraded the replacement regulators construction some time after the initial design was specced, reason I think so is my drivers side original reg failed at 60,000 miles,again at 120,000 miles,and the part installed at 120,000 is still operating at 286,000.......
Personally, I would remove the inner door panel yourself,leave it in your garage before taking the car in for the regulator replacement. No technician is going to be as careful with it as you would be.sometimes a few of the plastic clips will break due to age/brittle plastic....easy and cheap to replace if it happens.Be sure to inspect and reseal the clear plastic door liner before replacing the door panel.
