Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Wed Oct 31, 2007 7:38 am
not true. I believe you can use just about any 93 or so to 97 engine. I swapped engines in my '98 as well and used one from a 2wd in the swap. I had to swap the oil pan and pickup, and the flywheel (donor was an auto and I had a manual). Beyind that, everything was a direct plug and play.
I don't believe the KA's changed in the HB years. If you do encounter anything different, replace the donor engine electricals with those from yours, but everything should be a perfect or near perfect match.
