i relocated my knock sensor because it was getting a check engine light, so now its on top of the manifold/plenum
no check engine light now thank goodness.
now a question i've probably started up the pathfinder up 20-30 times since the relocation of the knock sensor, today making my rounds today with the vehicle when i turned the key it cranked and died a couple times. so when i cranked it again i lightly pressed on the accelerator to keep the engine from dying everything seemed fine
i wonder what caused it to die
i also notice RPM's are a bit lower, but if i hit the overdrive button the RPM's are much higher
but before the knock sensor relocation the regular RPM's were higher and the Overdrive was lower
seems the knock sensor changed a few things, i'm not complaining, as long as i can make it start, was kinda worried that it died though but least got it going
