bill834 wrote:He then said there is a sensor under the intake manifold that is the problem and needs to be replaced. Seem $800 is alot to spend to see if he is correct.
If the sensor under the intake is the same as my 2001 then it is only a knock sensor & that would not prevent it from starting... Seems you need a better mechanic...
You are saying it "doesn't start"... Does that mean you turn the key and nothing happens?? Or you turn the key, the engine turns over but it will not fire?? Can you be more specific??
