I replaced mine with Pioneer tweeters a little over a year ago. https://www.amazon.com/Pioneer-TS-T110- ... B00009QOU5 They had been dead for at least a year before that. I too bought a Pioneer sound system many years ago. OEM replacements are not worth the cost in my opinion, at close to $70 each and sound quality not as good as others, like the Pioneers. Granted, the work to custom install what I did right where the originals were may not be worth your effort either but with a hole saw, some hot glue, and a bit of craftiness, they look good and sound great. There's a couple of pictures of what I did in the Amazon reviews.
I did and I used the same PAC ROEM-NIS2 system interface so I had no problems with compatibility issues. No strange speaker noises at all. I also used the PAC SWI-RC steering wheel control interface so I didn't lose the volume and channel controls on my steering wheel.A1218 wrote: ↑Sat Dec 12, 2020 5:24 pmDid you keep the Bose amplifier?
I’m going to use the PAC ROEM-NIS2 to retain the Bose amplifier.
Also, when you turn off vehicle you get a pop or muffle noise coming from speakers. Didn’t happen before so I guess it has to the with the Bose integration harness not being used?
I don't recall. It's been 5yrs since I set it up. Simply following the instructions is all I recall. I do remember there are wires for features that are not applicable and therefore not used but I don't remember the specifics.
Actually, I do remember. There is a power output wire for a power antenna that is energized when the radio is turned on and also a number of speaker wire configurations to cover various existing vehicle model configurations.
There you go, making me think.A1218 wrote: ↑Sun Dec 13, 2020 3:50 pmBut the speaker wires for the PAC has a high positive and a low positive. Many say it’s the high positive you use on the PAC when wiring to the radio. And there’s only one negative so that’s simple.
Also for the black ground wire, did you just wire to the PAC integration harness black wire? Or did you ground it straight to the metal in dash? Or connect both and ground to metal?
Wow, can’t believe you just did that for me. I really appreciate all the effort into helping me out.mdmellott wrote: ↑Sun Dec 13, 2020 6:03 pmThere you go, making me think.A1218 wrote: ↑Sun Dec 13, 2020 3:50 pmBut the speaker wires for the PAC has a high positive and a low positive. Many say it’s the high positive you use on the PAC when wiring to the radio. And there’s only one negative so that’s simple.
Also for the black ground wire, did you just wire to the PAC integration harness black wire? Or did you ground it straight to the metal in dash? Or connect both and ground to metal?I now vaguely remember having a conversation with Pac-audio tech support about these low level and high level positive speaker wires but my old grey cells they ain't what they used to be so the details of what and why have faded into the abys of things I don't what to remember. Therefore, just for you, I pulled my head unit out and took a look at what I did. I used the high level wires for all the speakers (wht, gry, grn, pur). The low level wires (same colors with a red stripe), I removed from the harness and tossed them out. The black ground wire from the Nissan harness connector I wired to the PAC harness black ground wire. None of the ground wires were attached straight to metal. The Nissan harness already takes care of that. The blu/wht wire is the amp trigger and the blue one is the power antenna, which I left alone in case I ever what to go that route in the future, but I'm satisfied with my stubby. (no short jokes please and this is not a reference to any body part)
Finding those OEMs would be a problem by itself.mdmellott wrote: ↑Tue Dec 15, 2020 8:24 pmExcellent! No adjustments needed on those tiny pot's for the speakers. Yeah, instructions are a bit anemic. Pac's tech support was good at answering questions though. I remembered those low level wires have something to do with adding an optional amplifier.
Your tweeters are toast. Not a surprise given their age. You can go the OEM route for replacements but the sound quality of others will be so much better. However, to mount new non-OEM tweeters where the old ones are will require a hole saw and a bit of hand crafting to make them look right. There are no aftermarket plug and play replacements for the OEM style. I installed Pioneer TS-T110 tweeters in my '02. They made a huge difference in the sound quality. I first tried out a $20 pair from AutoZone. Fastest $20 I ever wasted. Don't go cheap on these but you don't need to spend much either. The Pioneers are only $40 for the pair.
FYI: I couldn't help myself so I went ahead and purchased those Kenwood speakers I previously mentioned, along with the Metra adapters. They are not plug and play. They don't even fit unless I remove the entire Bose amp set up and then the cables are incompatible connections and the Metra adapters do not resolve that. I just returned the purchase for a refund. I had installed one speaker with a trial fit before hand and it actually sounded absolutely terrible. I'll stick with my Bose speakers.
Well there goes that project lol. Good thing I didnt order them yet.mdmellott wrote: ↑Sun Dec 20, 2020 3:33 pmFYI: I couldn't help myself so I went ahead and purchased those Kenwood speakers I previously mentioned, along with the Metra adapters. They are not plug and play. They don't even fit unless I remove the entire Bose amp set up and then the cables are incompatible connections and the Metra adapters do not resolve that. I just returned the purchase for a refund. I had installed one speaker with a trial fit before hand and it actually sounded absolutely terrible. I'll stick with my Bose speakers.
Nicely done! That is a very clean install. Those would have been my choice had I seen them first. What brand/model are those tweeters?A1218 wrote: ↑Sat Jan 02, 2021 10:40 amHeres some pics of the new tweets and stereo system.
https://imgur.com/gallery/HqnOtBD
Thanksmdmellott wrote: ↑Sun Jan 03, 2021 12:33 amNicely done! That is a very clean install. Those would have been my choice had I seen them first. What brand/model are those tweeters?A1218 wrote: ↑Sat Jan 02, 2021 10:40 amHeres some pics of the new tweets and stereo system.
