A1218 »
https://forums.nicoclub.com/a1218-u297613.html
Tue Feb 02, 2021 8:15 pm
I got the vehicle into 4 low, I wasn't pulling it far enough backwards so I was essentially just putting the transfer case in neutral, which would explain the revving. Everything is working fine, 2H, 4H, and 4L.
I dont believe the transmission went into fail safe mode as it goes through all gears fine at its correct shift points with no slipping or jerking or anything that would make you think theres a transmission issue, even after I got that blink. The light does come on every time the ignition is turned on like you said to indicate the light works then it comes off. And it does come on and off when pressing the o/d button, so everything is fine with that.
What I believe was causing the light to come on yesterday when I restarted was due to the fact that I previously had the transfer case in neutral while the transmission was in drive as I thought I was in 4 low but really was not. So I turned off the vehicle and put the case back into 2H and when I restarted thats when the o/d light blinked about 16 times then came off. Again that only happened after I had put the case in neutral and the transmission in D and was trying to drive.
That possibly caused the TCM to think theres an error or to indicated the t-case is in neutral when starting? Just a wild guess based on the circumstances
Other than that no o/d light blinking, not during normal driving in 2H, nor 4H or 4L driving or starting the engine in any of these modes.
But out of curiosity and to make sure everything is really fine, I'll run the manual diagnostic to see if theres any codes based off the blinking pattern.
