97 Pathfinder Stalling on Deceleration?
MrTwister
Hello Gang Thank You in Advance for your help.
97 Pathfinder 4x4 103,000 miles
My car starts and runs fine but will stall on deceleration. When driving and on deceleration the RPM's will start bouncing up and down then the car will stall out. Typically it will start back up without issue. I have cleaned the MAF, New Fuel Filter, New Fuel Pump, Fuel Pump Relay clicks fine when key is turned and checked the Fuel Pressure Regulator and found no gas in the vacuum line. I am at a bit of a loss at this point as I had thought it was a fuel delivery issue. Car idles fine and has power on acceleration but will stall on deceleration or at a stop light. No check engine light and no codes at this point. What are your ideas? What have I missed?
Thank You
