Gotcha, will try the timing light. Never used one before but I’ll see. Any recommendations? I know it should be 15 degree +/- 2 degrees.VStar650CL wrote: ↑Wed May 19, 2021 1:33 pmWith a "by ear" timing setting, the ECM may not have enough latitude to correct a knock situation. Get it timed right with a light. If you're a "grandpa" driver it's also possible you have a carbon-buildup issue. Carbon on the piston crowns artificially increases compression and can induce knock in an engine that didn't used to do so.
Is that a safe option? Just wondering, it won’t damage anything?VStar650CL wrote: ↑Wed May 19, 2021 1:52 pmWarm it up fully, have an assistant hold the RPM's between 3~4K, and put a teaspoon of any type transmission fluid down the brake booster hose. Bam, no more carbon.
Alright, I’ll give that a try if adjusting the timing doesn’t work. I ordered a timing light to adjust it this weekend to 15 degrees if it’s not timed right.VStar650CL wrote: ↑Wed May 19, 2021 5:59 pmYes to Q1, no to Q2. We probably de-carbon 5~10 cars a week that way, the only small risk is that big chunks on a severely-carboned engine can hit a spark plug and bend the electrode shut. The ATF pretty much "explodes" whatever carbon is present by means of thermal differential, not much different from tossing an ice cube in boiling water. It doesn't melt, it cracks. To Q2, dirt can hold seals together on an old car, but carbon isn't dirt. No amount of carbon thicker than a hair is healthy on pistons or valves.
So I checked the timing and it is slightly under the 15 degree mark. But it would still be within spec because it’s 15 degree +/- 2. Should I adjust it to exactly 15 degrees?VStar650CL wrote: ↑Wed May 19, 2021 1:33 pmWith a "by ear" timing setting, the ECM may not have enough latitude to correct a knock situation. Get it timed right with a light. If you're a "grandpa" driver it's also possible you have a carbon-buildup issue. Carbon on the piston crowns artificially increases compression and can induce knock in an engine that didn't used to do so.
Correct, more advance will only exacerbate it. I'd leave it alone. Since the problem is heat- and load-related, I'd pull a couple of plugs and see if the cylinders are running on the hot side (white-ish electrode). If so you might have an EGR issue or something causing lean fuel.
