always using 87 octanes
well I got a second ,third and fourth opinions
My mechanic friends were concerned that perhaps i didn't do the tensioner right and it has skipped a tooth
so I took all the covers off again just to check , sure enough everything looked ok
I buttoned it back up again (2 hours)
started it - took a long time actually to start
run perfectly
took it out for a spin
3 blocks down the road it died completely all of a sudden
could not start it at all
we checked for spark
there was none
played around measured stuff finally decided to get a new distributor
put new distributor in ($250)
started right up
runs smoothly ever since
looks like an intermittent problem with a dying part in the distributor - (surprisingly easy to change)
I'm pretty confident my problem is solved
THANK YOU VERY MUCH ARKQX33V6 for your suggestions and emotional support
If you're ever in Petaluma I'll buy you a beer
next project changing blown shock in the k-sport coilovers in the 240sx
