97 Pathfinder Led Brake Lights
A1218
Car: 1997 Nissan Pathfinder SE
I tried out some led bulbs on the brake lights and they work but prevent the cruise control from engaging. The only solution seems to be load resistors for each light. But are they safe despite producing so much heat?
What's the best place to mount? I'm concerned about a fire hazard.
I already have LEDs everywhere else on the vehicle, interior, and exterior, except the fogs. But I have installed led off-roading lights on my bumper in case needed. For the turn signals, I simply changed the relay for led compatible to prevent the hyperflash.
Mike W.
Car: 2003 Infiniti QX4 with a drinking problem. Gone but not forgotten
2002 BMW 525it
2002 BMW 530i/ manual trans
The dark side, 2008 4Runner.. We'll see.
Interesting, this just came up on a BMW forum I'm on the other day. Apparently canbus compatible bulbs are the ticket.
https://www.mye28.com/viewtopic.php?f=3&t=156874
A1218
Guess I'll try them out.
I know this vehicle does not have a canbus system though.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I don't think you'll need a hefty ballast on the brake circuit like you'd use to prevent hyperflash on turn signals. The cruise will be a leakage/voltage issue and not current. I'd try something like a 330 ohm 1-watt and see if that does the trick.
A1218
VStar650CL wrote:
Fri Aug 20, 2021 12:19 pm
Alright, will do. And I install that on both brake light connections correct? Or just one side?
Thanks
VStar650CL
Technical Expert
No, one spot should be fine. Anyplace from the brake circuit to ground, location won't matter.
Mike W.
2002 BMW 525it
A1218 wrote:
Fri Aug 20, 2021 11:11 am
Neither do 80's BMWs. But they need to see ground thru the brake lights for CC to work. I'm guessing canbus lights include a resistor. But other than conceptually I have no idea.
