bmlawless »
https://forums.nicoclub.com/bmlawless-u85265.html
Wed Mar 05, 2008 9:06 am
Congrats on your new purchase. You will love your Pathfinder. If this one turns out to have more problems than you want to deal with, don't be afraid to buy another one down the line.
1) Check the child safety lock on the door. This should be a small switch located on the door itself frame near the door latch. It keeps kids from being able to open the door from the inside. It shouldn't affect the operation of the door, but if it is halfway between locked and unlocked, it could cause problems. Other than that, check the striker bolt on the latch. When the door closes, the latch on the door locks around a heavy bolt on the vehicle. There should be some sort of plastic coating on the bolt or the door (or both) If the plastic is mangled, the door can stick. My pickup does this.
2) Don't know on this one.
3) Take it to a shop and see what they say. If you have a throwout or clutch bearing on the way out, it is better to get it fixed now before bits and pieces get into the clutch and transmission and cause a lot more problems.
4) These things are a joke.
