NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue Jun 21, 2005 5:32 pm
Shoot sorry about that musta missed your inital request. I am so sorry.
The simple way to set it with out feeler gauges is to use a volt meter and watch the voltage on the tps, there are 2 connectors one brown and one gray, the Brown one is TPS one of the wires should be white. That is your signal wire. with it plugged in and ignition in the on position but engine not running, stick a T-pin or a filed paper clip in the back of the connector where the white wire is till it bottoms out. Place your neg lead of your volt meter on the neg battery cable and your pos lead on the T-pin, see what its voltage is. Should be between .45 and .5volts. If it is not in that range loosen the 2 screws holding it to the throttle body and twist it gently till you obtain that range. Tighten it down and be sure it is still in that range. That will get it very close to dead on. Now get in the vehilce and turn the key off wait about 10 secs. turn the key to the on position, dont start the car, wait for the air bag light to go off. Turn the key back off,wait 10 secs again. Repeat this process three times. Basically you should have watched the airbag light three times. wait ten seconds after turning the key off after the third airbag light time frame and then start the car. what that does is clears the self learn in the ECM. Sometimes it doesnt and the car will require some driving to reset it.
