ahardb0dy »
https://forums.nicoclub.com/ahardb0dy-u30854.html
Tue Dec 22, 2009 8:27 am
My problem was the wires as I said they were fairly new they were just aftermarket ones, no indication there was any problem with them but I live in Florida and I was back up in NY (where I am from and have connections with the local Nissan Dealer) and I picked up a set of factory wires at a discounted price, when I got back home I swapped the wires and problem was gone. The bog off the line was so bad before like it was getting no gas or something, factory wires on ran like new.
Side note when I had my 87 SE-V6 hardbody took off the original wires and installed a set of aftermarket wires, a number of miles later (60K or so I recall) the aftermarket wires were do to be replaced and I thru the factory ones back on and it ran just fine even though they had a lot of miles on them,
bottom line is certain OEM parts are worth paying more for and don't even think of using any spark plug other than NGK, they may be the cheapest but our Nissans run best with them.
Your best bet is to take the truck to someone who can diagnose it, I hate shops that just keep replacing stuff until they find out what is wrong, it's fine to accept advice on what MAY be wrong but if it doesn't fix your problem it can get expensive doing the trial and error method of auto repair. Example of this below:
My neighbor has a jeep Cherokee that wouldn't start it would just crank, I went online and discovered a LOT of people with the same problem, crank sensor, they were friends with a guy that owned a local shop and had him come over to look at the jeep, he came over with his $20,000 Snap On computer (which he couldn't get to connect with the trucks computer), he tried the redneck method, tapping on the computer with a hammer!!!!, than replaced the ignition pickup thing in the distributor, nothing he did worked, than he said he would bring a new computer to try, few days later he showed up with the computer, still wouldn't run, oh, forgot to mention I told him about the crank sensor and was ignored, anyway few days later I see the jeep was moved, went across the street to ask my neighbor what it was that was wrong, GUESS WHAT it was ?? crank sensor!! A-hole!!
