whomadewho »
https://forums.nicoclub.com/whomadewho-u165512.html
Thu Aug 13, 2015 5:26 am
For your saftey and the saftey of your family,and other drivers I would reccomend taking the truck to a professional. The torsion bar has a lot of tension and you can cause injury to yourself. The adjustment bolt is fine threaded and most of the time with out the proper tools,the bolt will either strip or break off. When you take it in,the shop can inspect the ball joints,sway bar links, control arm bushings,front wheel bearings, rear leaf springs. Most shops can do a 4 wheel alignment, which insures maximum control,tire wear and fuel mileage. Without the proper knowledge,when you mess with the torsion bars it can actually cost you money due to excess tire wear and lower fuel mileage.
