88m5 »
https://forums.nicoclub.com/88m5-u93583.html
Wed Jan 01, 2014 4:39 pm
Hope you guys can help. So i been trying to chase this problem of High idle (1500 in Park) and then after a few minutes it will go down to 800-900 and stumble for a minute or two and then back up to 1500. So I installed a new IAC valve which made it worst so installed the old one back on. I check the TPS and adjusted it by the NTB99-053b and still the same. I check the EGR and it seems fine. The truck runs like a bat out of hell great other than the idle. I check all the vacuum lines and even sprayed WD40 around the TBI base and intake no vacuum leaks. I also do not get any codes at all.
About a year ago I installed a new MAF which I got from Courtesy Nissan so it original Nissan, Converter, and both Oxygen sensors.
So I am kind of stump here any suggestions would be great.
Thanks
Chris
